Aimee's 2021 WK2 Grand Cherokee Trailhawk
Posted (edited)
@aimee got some smoked rear bumper reflectors for Christmas, so i installed those today:
before:
ACtC-3eGvIKR2WDrDWYr4l_cmvb3o_nilcJyox51
after:
ACtC-3fn6CYxz7nr4at_9bDADTEVLQTiS1mshDXV
@aimee pointed out that the 3rd brake light was still red too...  since i had some VHT Nightshades, i went ahead and tinted it.
FYI, as an alternative to paint, here is the nicest looking dark/tinted aftermarket one i could find (for 2017+ WK2)...
i scuffed the factory light with #0000 steel wool, then also lightly sanded between coats with the steel wool. i finished with a coat of Dupli-color clear gloss top-coat
ACtC-3cYdjbbgwlRHU17XU85SDgiAa-KW3kSRtj1
it came out a little darker than i meant to go, but i think it still puts out enough light.
ACtC-3eS7-HuSHbkiNWXxIzpNxiGgLZsPazmUqpm
ACtC-3fo5wSQ-NtH2rTy1eRtEOcTa9VzBqjGbc-i
i couldn't find a write-up on how to remove the rear spoiler/brow for a 2017+ Jeep Grand Cherokee WK2 (plenty for older WK2's and WK's) - so here's that info for anyone else:
1) i would recommend you first remove the lower piece of interior plastic trim from the liftgate. it's just held in with clips, use a sturdy plastic automotive trim tool to work it out.
2) then for the top half of the trim, you need to pull each side of it inward (toward the center of the glass).
i broke 2 of the clips because i pulled the top half downward first (maily because i didn't remove the lower trim piece first) - oops!
ACtC-3fN4LW7VPqgRFIl82W-kygrJIRqiQF3JlpU
ACtC-3dMoA1WPo6gSuhKtgOOUP_2qz41KZ0IwzKy
3) once you have the upper half of the liftgate interior trim removed, you need to disconnect a single electrical connector just right of center (squeeze the tab, then pull apart).
ACtC-3eZDsD_73gEgjXMm_Ap7D_2GRD9aLUVEaST
4) and separate the washer fluid hose in the driver side corner.
ACtC-3fcW-36ckh-RjKelCcv8-BxDH47nSu13NyP
5) there are (5) 10mm nuts that need to be removed. (1) at each corner as shown in the previous photo, and (3) recessed inside the lift-gate. be careful not to drop them inside the liftgate!
ACtC-3cr7tZfadsCKoP0JaGB5Hs04XJ6rMRPq0XC
6) there are also 2 small white plastic clips in recesses like the nuts. squeeze the tabs on those clips with needle nose pliers and push them through the metal slightly.
7) close the hatch and the rear spoiler will just lift straight up off the Jeep... unless those 2 plastic clips are hanging it up - in which case you might need a helper to squeeze those tabs while gently pulling on the spoiler.
to remove the 3rd brake light from the spoiler, you just need to disconnect a single electrical connector and remove 2 screws - it's all obvious once the spoiler is off.
ACtC-3c9jd3dlJbsP_EXC4QDFe4d17lm9JZ_infW
That turned out nice! Are you guys planning to "murder out" the tails as well?
Looking forward to seeing it in person. @Bradywgn71's "Cupcake" looked awesome in person.
nah i like the stock tails, they look like they belong. the bumper reflectors were the only ones really bothering me. those just looked "tacked on", like a afterthought - darn newer safety regulations!
created this GIF animation right after we first got her, showing the different modes of the Trailhawk's factory air suspension (Park, NRH, OR1, OR2):
ACtC-3dSvqPFLpDiMOivqB6MUfcfm9dm_cLbvGx_
there's supposed to be about 4.1" of change, resulting in a maximum ground clearance of 10.7" in the Off-Road 2 mode.
  • Wow 1
really happy with the WK2 for road trips! this week it took all 3 of us and one of B's friends (and all our junk) up to Pinetop-Lakeside to stay at a cabin for spring break. we got several inches of snow one day and were confidant driving around in it and the next day's mud thanks to the WK2's various "modes".
ACtC-3f2I5l6R2LBwAz1fhJ68d_5g1rBK5eqX3wL
ACtC-3cvGYf2ZByJQ4RD2MIpZPPaynVR8bpoRDaW
ACtC-3eqYY0w2N5Yq_2mOWUj0YeDvTxXfnBr9-Ge
  • Like 4
  • Love 2
spent some time getting her clean today... the OEM felt wheel-well liners might be good for reducing road noise, but they really don't belong on the Trailhawk. they're mud sponges!
ACtC-3dSD6RMsG1eWdkq25w4iUcRQN0K-1wBH40T
  • Haha 1
  • Wow 1
Posted (edited)
finally took the WK2 camping and got her a little dirty at least!
ACtC-3epPRUhfmcxlkzJ5iyZ49MBsMDdo_kmNngj
ACtC-3fg6SV7VlZWtCuMYn5S5CU3rN99ddv5XzVG
Posted (edited)
Aimee let me drive it some since Gadget isn't feeling well, so of course i stop and take random photos ;)
ACtC-3ciEYgrMOutoK_pxDPG4IRmDNUnbdG1GuaB
  • Like 4
She's been out in the gravel, make sure you put on two coats of wax!
  • Haha 1
