Stacey and Scott 963 Posted July 19 1 hour ago, 4x4tographer said: Hey @snoopy61! Sorry for the long post - but there's a lot to say on the subject! I personally use 2 different deflator options - you only really need one: Option 1 is the popular ARB ARB600 Deflator. It's been a workhorse - I've been using it for every trip for about 6 years without fail. It works by removing your valve core on your valve stems to allow the air to defeat very quickly. You have to manually monitor the pressure until you are where you want to be. There are several different, cheaper options out on Amazon. PRO: You manually control the pressure and can stop at any PSI you want for the trail conditions. CON: It takes a little longer to use to deflate since you're working 1 tire at a time. You also have to crouch while using it. Option 2: I also use a set of 4 Coyote Automatic Tire Deflators. They're very similar to this popular option from Staun that many folks here use. PRO: They're nice because you can deflate all 4 tires simultaneously, and automatically - meaning you can walk around, chat with friends, while the deflators do their thing. Once they stop, you just take them off and you're good to go! CON #1: You have to put in the time up front to preset them to the tire pressure you prefer to run on the trail. Once you have them dialed in, it's as easy as screwing them on to your valve stems and waiting for them to stop automatically, about a 4-5 minute process. CON #2: You're stuck with the pressure you set them to without the ability to easily adjust pressure to the trail conditions on when you're running (sand, rock, snow, gravel road - for example: you might want to run 20 psi for an easy dirt road, but 12 psi for sand, etc. There are some fancier systems out there, like those from MorrFlate, but they are pretty pricey - but well-designed for airing up and down with the same gear. What I do is: Initial deflation with my Coyotes (all set to about 16 psi) If I need to deflate further, I'll make some adjustments with the ARB. My recommendation for the first time user is to get the ARB style of deflator to get you started. You can always grow into some auto-deflators in the future. Also - if you air down - you're going to want a way to put air back in to the tires for the trip home! Don't forget a compressor! "Don't forget the compressor"...wait for it, compressor questions on the horizon. *Pretty much everyone has a comp setup so if you want to check out before you buy, ask around on your next run. 1 Share this post Link to post Share on other sites
4x4tographer 2,156 Posted July 19 36 minutes ago, Stacey and Scott said: "Don't forget the compressor"...wait for it, compressor questions on the horizon. *Pretty much everyone has a comp setup so if you want to check out before you buy, ask around on your next run. Haha! Totally! Especially with this group we probably have every compressor known to mankind covered. 2 1 Share this post Link to post Share on other sites
shellback91 1,309 Posted July 19 13 hours ago, 4x4tographer said: Haha! Totally! Especially with this group we probably have every compressor known to mankind covered. We sure do. I'd like to get a bougie 4 hose set up one day for my compressor. But that's a discussion for another thread. 1 Share this post Link to post Share on other sites
AZRNintheJeep242 381 Posted July 21 On 7/19/2022 at 9:18 AM, shellback91 said: We sure do. I'd like to get a bougie 4 hose set up one day for my compressor. But that's a discussion for another thread. They’re worth the money, so just go bougie already. 1 1 Share this post Link to post Share on other sites
shellback91 1,309 Posted July 21 14 minutes ago, AZRNintheJeep242 said: They’re worth the money, so just go bougie already. I definitely need to do some more research. I know there are a few options out there, I will look for the most bougie. 1 Share this post Link to post Share on other sites
AZRNintheJeep242 381 Posted July 21 Just now, shellback91 said: I definitely need to do some more research. I know there are a few options out there, I will look for the most bougie. Well I can speak for the Morreflate one and they’re pretty amazing and bougie. 1 Share this post Link to post Share on other sites
Ladybug 278 Posted July 27 FWIW - Remembering my first few runs, I just used an air gauge tool to deflate my tires, and borrowed a compressor a time or two. I totally recommend holding off on buying anything until you have 2-3 runs under your belt and then get something that you like. There's enough people on these runs to share tools and allow you the time to gather information for what you would like best. On the Casner run, we can help you at both ends...air down and air up. smiles, ladybug 2 1 Share this post Link to post Share on other sites
4x4tographer 2,156 Posted July 27 Two weeks and counting! We just received the permit in the mail this week - it’s official! WE’RE going to Casner! Looking forward to seeing you all for a beautiful trip! 1 1 Share this post Link to post Share on other sites
Scott Miller 18 Posted July 28 (edited) Please sign me up! 2 people Edited July 28 by Scott Millet Share this post Link to post Share on other sites
4x4tographer 2,156 Posted July 28 5 minutes ago, Scott Millet said: Please sign me up! 2 people Hey @Scott Millet, welcome to the Club! I’ll add you to the standby list. You’re 3rd in line at the moment. If you’re interested, there is a second trip planned for 9/24 that still has 1 open spot left for Club Members like you! Let me know if you decide to go on that run instead. Share this post Link to post Share on other sites
