Grand_Seltzer 57 Posted August 26, 2022 Just now, theksmith said: that looks nice! plenty big but much more tastefully integrated than the absolutely HUGE screens i see a lot of lately. does it take a few seconds to come on when you first start the rig, or is it just as fast up as a non-Android radio? It is a very fast boot. sub 5 seconds.. I had a 12" android radio in my 2013 ford fusion, I loved the size but it was a ~30sec boot up and it was awful. My experience, at least of these last two tells me all android radios have their nuances.. This one is working out swimmingly, having a plug-n-play solution along with a new radio trim bezel is just a few reasons to look at this one. 2 Share this post Link to post Share on other sites
Grand_Seltzer 57 Posted October 26, 2022 I've been inactive on the jeep for a little bit. On September 2nd my son Barrett was born. There were some issues we were somewhat expecting based on the ultrasounds and we spend about a week in the NICU every night with him. Everything is good now and finally getting back to normal.. with little amounts of sleep... Finally getting back into the mood of things on the jeep, have quite a few things ordered. I noticed my oil pressure gauge was intermittently dropping a few days ago. Today I noticed it again but I was also noticing my voltage read on my radar detector dropping to 12.7-13.2 area. So new 2g cables from jeepcables are ordered, optima yellow top, and a 160amp Dakota alternator were all ordered tonight. I may add on a new belt and tensioner just as a 'since I'm here' effect. And a bigger order was made for the suspension. I originally bought some 3.5" tj springs and shocks from iro, I'm deciding against this and going a little bigger. Stay tuned. 3 2 Share this post Link to post Share on other sites
Grand_Seltzer 57 Posted November 29, 2022 Hey Everyone, Still in prepping phase for the lift. Been doing some maintenance in the meanwhile. I found out my oil pressure was dropping was because I was about 4qts low on oil... That'll do it. Found my valve cover gaskets were leaking, I never noticed a spot on the driveway because they conveniently leak onto the exhaust manifolds and just burn off. Got that taken care of. My new Yellow top, Alternator, and cables all came in and got installed. Was sitting on a set of spark plugs and knocked that out last weekend. The positive was that all the, likely original, old plugs seemed pretty even. Nothing really stood out with one over another. I'm currently sitting on a new fuel filter and a full set of pre-bent stainless brake lines I need to get installed in the next few weeks. I also ordered a set of new 12 hole injectors from Ksuspension. There's no rush on this though, I dont have really any major engine issues but I just wanted to take some time to make sure this engine is as healthy as it can be. I wouldn't be shocked if I drop a valve one day, it's a 4.7, it's not an if but when. As far as the lift is concerned, I believe everything is officially ordered now if I don't already have it. I am going back to Illinois for Christmas with the family, plan is to drive up, Enjoy christmas, But the week of the 26-30th is going to be a thrash week. Full long arm kit installed in 5 days to run and drive. 4 Share this post Link to post Share on other sites
Grand_Seltzer 57 Posted December 12, 2022 Quick update, been accumulating all the parts for the lift and should have everything at this point. The long arm kit is pretty much done and ready, but I I've since decided to let the shop that built the long arms handle the install. The wj is currently at a local shop for new fuel filter, oil change, and since my new injectors arrived, probably those too. I dropped off to also do new stainless hard lines but the flex lines were so corroded they're holding off until I get my new flex lines in too. They did also manage to break a fuel line to the filter so it's sitting there until parts come in for that. Dropping off the wj on the 29 and won't be picking up until it's done early next month and is likely when I'll post the next update. 4 Share this post Link to post Share on other sites
theksmith 3,590 Posted December 12, 2022 fingers crossed for a smooth install at the shop! 1 Share this post Link to post Share on other sites
Grand_Seltzer 57 Posted December 30, 2022 Final update of the year. Hope you all had a fantastic holiday (s)! My wj spend close to 2 weeks at the local shop but finally got the fuel filter, fuel pump, the new 12 hole injectors and the oil change done before we had to boogie up to my parents house in Illinois. The shop ended up attempting to lift my jeep from the reach rocker and folded the pinch weld over and I'm pretty ticked about that since these are some of the cleanest rockers on a wj as you can find. Still working with them on this issue,but they did agree it wasn't right and will work with me on it. I did pick up a superchips f5 programmer while it was in the shop too. Yesterday I drove the wj from eastern tn to western Virginia for 4hours to a shop that will be handling the new suspension install. The drive there I actually got 19mpg while sustaining 70-75 and while I had probably 300-500lbs worth of parts loaded up in the back. I still really wish I could be doing this install myself but it just isn't plausible this time around. My garage,if I haven't noted, is a long small 1 car garage with no power. Even if I had power, I really couldn't get the jeep in with any comfortable working room let alone get it back out once it was done. I'm planning this next year to at least pave our driveways in, at least then I can have some more level space to handle maintenance. I'll post up some pictures later today. Everything on my phone is over 4mb 1 Share this post Link to post Share on other sites
Grand_Seltzer 57 Posted January 23 Well the WJ is back home after being built on in Virginia for a couple weeks. A few things changed as it was being built, I had to get slightly wider wheel spacers to clear the new steering. We decided to go to a 4.5" lift height vs 5.5" to save on additional drivetrain upgrades.. In the meanwhile I did pickup a np231 transfer case I plan to swap the 247 out with. Ultimately, the 231 is a simpler and more convent case until I've got enough time and patience to do a 241or as I was planning for in my last build. But the 231 has a plethora of upgrades like SYE kits and 6 pinion planetary, wide chain, it will be suitable enough for the interim. For now, the jeep is on its own weight but still needs a few things worked out. Biggest thing right now is it needs to be strung out and squared up and aligned. I found after my 4hr drive home the rear springs were very unhappy. I have already made a small adjustment to the rear arms, and it's better, but I decided not to do much else until I can have it fully aligned. I don't have any concrete to even set it all out on so I'm going to farm this job out locally to an actual 4x4 shop who has an alignment rack sometime this week. The list of goodies I am working with now to satisfy some curiosity; Trail Forged Long arm front and rear Trail forged ultimate steering kit with 1 ton Tie Rod ends and Raised trackbar Metalcloak TJ 3.5(4.5 for wj) dual rate spring front and rear Bilstein 5125s 11" shocks Front JKS quick discos A couple of things on the shelf that are on the to do list; New THOR intake New muffler(currently straight piped and dumped under the rear passenger seat, sounds fantastic if I was still 18) Auxbeam switch Panel 231 case as mentioned before ZJ washer bottle A grinder to start hacking up the front bumper Yeah that spring is not so happy! 2 1 Share this post Link to post Share on other sites
Grand_Seltzer 57 Posted January 24 Forgot to post a good shot of the new steering. 2 Share this post Link to post Share on other sites
Grand_Seltzer 57 Posted January 30 It would have been fine if I was still 18. Back in the day, exhaust can never be too loud. I distinctly remember my old TJ, cutting the muffler off then running it for weeks open cat just dumped under the skid plate. I followed that up with a glasspack that was so long it basically was a joke. My last wj was still a full through exhaust but no muffler, honestly that sounded pretty decent from what I remember. My JKU went 1 year with a muffler before it was removed.. (I've never had to do emissions testing in my life btw lol) When the jeep was about a week from done, they called to let me know basically the muffler that was on the jeep wasn't going to work. We went back and forth a bit but I ultimately told them, hey let's not waste time on it, Ill order something up and just put a pipe in it for now to get to dump in the right spot so I can get home. Last weekend I finally got the magnaflow I ordered welded up and I'm quite pleased with the result. It has a nice deep idle tone that reminds you a V8 is under the hood but it doesn't scream down the road to remind you, your family and your neighbors of it. Before and after clips Before: https://i.imgur.com/g6RgmVl.mp4 After: https://i.imgur.com/KQrK7qG.mp4 1 Share this post Link to post Share on other sites
theksmith 3,590 Posted January 30 after sounds better for sure, IMO anyway by the time i sold Lafawnduh, i was getting tired of the volume from the Flowmaster Delta Flow 50 with the immediate turn-down. 2 Share this post Link to post Share on other sites
