theksmith 5,822 Posted August 17, 2022 (edited) got everything put together with the custom bracket. the only place i had to modify the parts thus far was trimming the lower outside corner of the ACM panel. the Jeep's tub curved more than i realized there. i think that's not too shabby for having measured everything with a tape measure and just visualizing how the 2D pieces would fit together in my head. now i just need to take it back out and paint the raw aluminum. i'll also start mounting all the fuses, renogy controller, disconnect, etc. to the ACM panel as soon as i have more free time. Edited August 18, 2022 by theksmith 7 Share this post Link to post Share on other sites
WILL E 525 Posted August 18, 2022 That turned out very nice! 1 Share this post Link to post Share on other sites
dzJeepChic 2,908 Posted August 19, 2022 X2, that looks great, K! 1 Share this post Link to post Share on other sites
theksmith 5,822 Posted August 19, 2022 (edited) a little early morning rattle can action: and the house bank distribution panel is coming together, time to start making cables! Edited August 19, 2022 by theksmith 4 Share this post Link to post Share on other sites
theksmith 5,822 Posted August 25, 2022 (edited) making good progress... i didn't purchase a shunt/monitoring system yet, but otherwise the power distribution panel is done (pic below). i'll still need to connect several wires into the Jeep after it's mounted. everything is packed together pretty tight, which was unavoidable but does make the panel wiring a little messier looking than i'd like. i put an aluminum & fiberglass heat shield between that 120v charger (blue thing) and the battery since they are almost touching. the Renogy has cooling fins on the back and is supposed to be mounted vertically like this for passive cooling. the slots cut in the panel behind there are just to give it even more breathing room. after we get back from the Dusy-Ershim trip, i'll run the large gauge wire from the main battery back to the above contraption and do a little rewiring so that most accessories are powered from this instead of the main. then hopefully everything just works! Edited August 25, 2022 by theksmith 5 Share this post Link to post Share on other sites
theksmith 5,822 Posted September 19, 2022 (edited) i finally had some time to run two large wires from the engine bay to the rear (2 AWG power wire). one feeds the DC-DC charger in the back from the alternator and the other will be power coming back from the house battery to my existing aftermarket fuse/relay box. i chose a spot on the driver side of the firewall to drill the big hole. this is the second one of these Daystar rubber firewall boots that i've used. i add some RTV on the metal edges to help it seal water-tight. i've been using this generic version of Techflex F6 split braided sleeving instead of split corrugated loom lately. 3/4" diameter worked well to cover the double 2-AWG cables. after hooking up these cables to the rear power panel, i could finally finish the other big connections and install the battery. i'll want to make some sort of cover for the panel i think. so far, in terms of loads, i've only re-wired my rear power ports and fridge to run off the new lithium house battery. i made this little breakout/switch box for the cargo area out of a plastic project enclosure, 12v locking socket, rocker switches, and a 3D printed dual Anderson PowerPole (PP45) port from eBay. the reason the fridge is on it's own switch is the Dometic only has a soft power button instead of a true mechanical switch, and so even when "off" it's electronic control panel draws a bit more current than i think it should to leave connected all the time. the second switch isn't used yet, but might be for a cell booster or other "at-camp" accessory one day. i still need to do some additional rewiring to have the rest of my accessories fed from the house battery. with all this done i could test out the 120V 17A BT Victron Charger and my new Victron 500A Smart Shunt that you might have noticed got added to the main house distribution panel in one of the above photos. the single Victron Bluetooth app showing both devices: here's the 120v shore-power charger's main screen: and the SmartShunt's main screen: in the screenshot above, only the fridge is connected to the house battery and so the current through the shunt is a negative number (i.e. power is being drawn). it was just cycling off, hence the very low amp draw. finally i was able to also crank up the rig and see the Renogy 50A DC-DC charger do it's thing. here's another screenshot from the SmartShunt's app, this time the Renogy charger is supplying more power to the battery than the fridge is drawing, hence the positive current number. i also took a brief run down a nearby wash to make sure the mounting platform and battery hold-down are going to be secure. i have a slight vibration/rattle, but i think just adding one more mounting point at the top of the distro panel will calm that down. you can just barely see the house battery hiding beside the fridge when looking from the rear: so all the core elements seem to work as intended! now i just need to do that additional accessory rewiring and i want to clean up some cables going to the starting battery's fuse panel too. then hopefully this project is complete. i'll get to fully test at least the fridge and my 12v oven running off the new system on the Rug Road trip i'm leading next month! Edited September 19, 2022 by theksmith 3 1 1 Share this post Link to post Share on other sites
jgaz 752 Posted September 19, 2022 Nice job Kris. Very clean build. I like your breakout box and good job picking up the “vampire” loads on your fridge. I did a build once at work where the constant current draw drove me nuts until I realized that off didn’t really mean off on a particular piece of instrumentation I installed 2 1 Share this post Link to post Share on other sites
theksmith 5,822 Posted September 20, 2022 a fairly quick project this morning to rewire the PowerPole port and cigarette lighter style outlet that i'd added to the center console so they are both powered by the house battery now. 2 Share this post Link to post Share on other sites
ob1jeeper 855 Posted September 23, 2022 Clean install for sure Kris. Well done... 1 1 Share this post Link to post Share on other sites
theksmith 5,822 Posted October 10, 2022 (edited) this weekend i finally got around to cleaning up some things on the OEM starting battery side of things.. i had installed a Rugged Ridge dual battery tray a while back, before i knew where i was really going with this whole project. it came with a cheapo strap as a hold down, so i replaced that with a section of steel C-channel, and some threaded rods which i welded wing nuts to the end of. i put a strip of ABS plastic under the steel just to keep from accidentally ever shorting out against the positive terminal. i also replaced the factory terminal clamps that i could never seem to get tight with some of the popular "military style". however i used quick clamp style tighteners from these other clamps. i wanted those as an emergency disconnect since i didn't install a whole big battery cutoff switch. i was surprised how much corrosion was inside the factory wires near the OEM clamps. then i fabbed up a little fuse panel that attaches to my battery hold-down with 2 thumb screws. everything all together: i made sure to leave enough slack in all the cables that i can easily move the fuse panel out of the way if i need to change out the battery. other things used in this project: - braided loom - crimp terminals & heat-shrink strips - Bussmann MIDI fuse holders - large gauge crimper - large gauge cable stripper i've also started labeling the ends of all my added wires. the wire-wrap mode on an Epson PX700 label maker with their 1" vinyl flex tape works great for these large gauge cables. i set it with 2 lines repeating, the top line is what that end of the cable hooks to, the second line is where the other end of the cable runs to. so for example: S FUSES AIR COMP for smaller wires i use the "flag" mode on the labeler, but still follow the same 2-line method. Edited October 10, 2022 by theksmith 4 2 Share this post Link to post Share on other sites
