Surfy
Vanlife / Overlanding off-grid battery solution(s) with solar
We all know our discussions about the use of the Ecoflow River Pro as a electricity concept and battery setup in our rigs, to save weight and space. I did use this Setup for the last years, what was strong enough for fridge, notebook, smartphones, drone and even for charging my ebike during my recent trips.
A small and lightweigt battery box with everything embedded: wall charger, solar charger, inverter, battery.
Now at 2022 are some new solutions around who brings really a lot more Power for those who need that.
Today we can already buy the next generation of those devices. And we can see the first travellers out there, who start to cook with power consuming induction cooker with such "Portable Power Stations".
Here a concept for using at example the Ecoflow Delta 2 (LiFePO4) as battery for overlanding vehicle:
How to charge the Delta2
Cigarette lighter socket (100 watts),
220v shore power (1200 watts),
Solar Charge Controller: 500 watts (11-60 V, 15 A)
optional: by 12v «dc dc booster» (example with 240 watts at xt60 Port)
What can the Delta2 power up?
2x USB-C with 100 watts
several USB-A connections
4x 220v sockets 1800-2400 Watt
12v cigarette lighter socket 12.6V 10A (126w Max)
Article: Ecoflow Delta2 (& other coming products):
https://vanlife.4x4tripping.com/2022/10/vanlife-off-grid-battery-solution-with.html
In terms of price/performance/weight and compactness - hard to beat by an DIY Project.  Too this solution is expanable by external batterys. The available App let you use the capable battery monitor and allows to adjust a lot of values (like charging power). You will find links to other upcoming products of bluetti. Too ecoflow will release the River2 inside of the next 2 weeks, for those who think that the delta2 is a bit overkill.
How we can use a "12v dc dc booster solution" for a stronger "in car charge" is explained too, this way can be used with other "Portable Power Station" brands like bluetti or jackery in a similar way.
Personally I would even consider this concept for a bungalow or tiny house together with solar - the delta 2 is strong enough to use 220v coffee machines, water kettle or induction cooktops or other 220v devices like a fridge or even a washing machine.
Surfy
