Perry Green 8 Posted December 31, 2022 Anyone done an fj rear axle swap? If not I’m looking for a good locker that works well with this AWD setup. Any advice or pointers is appreciated. 2 Share this post Link to post Share on other sites
theksmith 4,150 Posted December 31, 2022 @lofreqjeff have any relevant 'yota knowledge you could share? 1 Share this post Link to post Share on other sites
lofreqjeff 94 Posted December 31, 2022 2 hours ago, Perry Green said: Anyone done an fj rear axle swap? If not I’m looking for a good locker that works well with this AWD setup. Any advice or pointers is appreciated. You mention AWD, I assume it’s a V8? I have not heard of this swap but it makes sense. You may be able to just swap the 3rds and wire it up. In my 89 4Runner, the rear diff with factory elocker is from a 99 4Runner and the front diff with factory elocker is from a 97 FZJ80 - both have wire harnesses from Low Range Offroad. 1 2 Share this post Link to post Share on other sites
Perry Green 8 Posted January 1 Everything I've read the 3rd mem swap requires more modification and hole drilling. 07 FJ full axle swap looks pretty much like bolt on then wiring, maybe a bit of fab but much more striate forward. I have had no luck finding a good used one, while I look I thought I would reach out maybe come up with different/better option. I appreciate the input i will look a little harder at the 3rd mem swap. 1 Share this post Link to post Share on other sites
