SonoranWanderer
Free (mostly) JK parts - clean out my garage!
Edit 20230130 1830 - added a few more items
Edit 20230201 0930 - more items, cross out some items no longer available
Free to good home. Trying to make my wife happy and clean out the garage, and YOU can help!
I have the following items that need a new home:
  • Bag of common trail repair 3.8L engine parts (hose, belt, tensioner, idle pulley)
  • 3.8L fan control module
  • Passenger side rear (red) tow hook for JK. Does not work with JL!
    • Full kit: hook, in-frame backing plate, bolts
    • Newer JKs (2015+ I think) have the holes in the frame factory drilled
  • SuperChips programmer for 07-11 JK (will need to contact and pay for a reset from SC)
  • Tailgate CB antenna mount, driver's side '07-18 (with cable)
  • Third tail light for JK from the stock tire mount
  • OEM replacement carpet clips (3)
  • Radio antenna conversion kit to combine CB with AM/FM antenna for JK, supposedly can work for JL too
  • Over rearview mirror CB mount for JK
  • Rugged Ridge/Omix Ada replacement driver's side door hinge for JK. This is just the door component.
  • Quadratec front and rear mud flaps for JK stock fenders
  • JKS 0-2" lift front swaybar disconnects for JL or JT
  • KC light rock guards (2)
  • KC stocking (you Jeep deserves Christmas too!)
    • Ok, even Yotas deserve some xmas love...
  • Tailgate CB antenna mount, passenger's side '07-18 (bracket only)
  • JK under front seat mounting bracket for air compressor, amplifier, or communications radios
    • Does not fit JL or JT
  • Set of 23 JK OEM acorn lug nuts (well used)
  • Set of 20 JL/JT acorn M14 lug nuts plus three lock nuts with lock key
  • Set of 25 7-spline M14x1.5 black lug nuts (fits JL or JT, not JK)
    • Includes 2 lug keys
    • Not a standard spline count, good for annoying both the tire shop and wheel thieves
  •  8 ton Vault Cargo snatch block with grease bearing (good for UTV winches) - never used
    • Not recommended for use with 10k or 12k winches
  • 20 ft, 10000 lb Vault Cargo tow/tree strap (30k break strength) - never used
  • 8 ft, 10000 lb Vault Cargo tow/tree strap (30k break strength) - never used
My bad pack rat habits, possibly your gain. I hate to just toss it if anyone could use any of these parts and pieces
AMWts8BW_DqZE5wXlM6qEnxKWBCX-TFSJaDfhQe0
AMWts8BYEKvWD-nhAeBL3Th0L_QG14V7Q2OdBCS6
AMWts8Du6fJtgZTEdJchvt0xqBRjss8xH7bIOC01
AMWts8DE0j339h0wZHixh_EBfyTN4JASW_rSCL6EFMNhOlvV3DH0eTqYrS0I54fI7fEGqotkdDvy5rdWzpAGPbmRH0EekcckRCabKa5dbypQSLntnKay_ybbb-sOaoGYKRkHrHCOxLzVhZb69raQf4ojx3HWNw=w1215-h912-no?authuser=0
AMWts8CweGOZ4n2GcO1ytRauDK9aZuwAw9ZlsIh8UiJmFkz3vIjQpVb87uQeQxMLnCraaIppOBtLA3pxD2pegVERj6NHTOlYTxVKPA89Defv4pb2Ayu_R1RO_G6kdmijaw_a3QowDoP4cissL15vyHRZKb3JWg=w1215-h912-no?authuser=0 AMWts8Db8Fqohcs-GtVwY3beJGNMIaL0wtJQaVGBWp-7CdXmBGPTu--yvvy9kWGL5jScwUR5tp6FwF8j5ss_B9tjtC6JdsYfmAoCymgJzUgdUX6IxXpSkOPPZJz1su7libYbAvpcpRkQDfXrCctn9wtWMEC24g=w1215-h912-no?authuser=0
Edited by SonoranWanderer
@MzPrisswith your new jeep?
i'll take these items please:
thanks Woody!
thanks Woody!
@theksmith  Noted and reserved.
For everyone else, more items added.
I’ll take this item please  if still available
Thank you sir,
Jim
Thank you sir,
Jim
Reserved!
