Curly
JL Factory spare tire holder
I need to extend my back up camera to clear the wider rim and tire cover I installed.  If anyone has a take off factory carrier, I want to try experimenting with ways to extend the camera support before I cut mine up.
thanks
Tim
Posted (edited)
In my JK, I put the backup camera in the bumper, and here is someone who relocated the JL factory camera to the bumper:
https://www.jlwranglerforums.com/forum/threads/backup-camera-relocated-out-of-spare-tire-and-into-rear-bumper.16730/
The response on that thread has more installation details:
https://www.jlwranglerforums.com/forum/threads/backup-camera-relocated-out-of-spare-tire-and-into-rear-bumper.16730/post-749461
In this same thread someone mover the camera to a bracket looping over the spare, but they don't say of they found or fabricated that bracket.
https://www.jlwranglerforums.com/forum/threads/backup-camera-relocated-out-of-spare-tire-and-into-rear-bumper.16730/post-421260
Camera Extension cables in case you want to fabricate a relocation bracket to go over the top of the tire:
https://www.amazon.com/Backup-Camera-Extension-Cable-Compatible/dp/B09G5XQHM7
https://www.quadratec.com/p/rox-offroad/backup-camera-extension-wiring-wrangler-jl
Edited by SonoranWanderer
@SonoranWanderer  Thanks for the info.  I had looked around on google/JL forums/FB and haven't seen what I want yet.   I am thinking of making my own extension for the camera in the stock space. Problem is, I don't weld.  The extension over the tire also seems like it would be fairly easy.
I totally understand which is why I think the in camera in bumper solution might be more efficient route. A mild pain to reroute the camera cable, but I've done that before and it only requires time and patience with basic tools, tape, and zip ties, no fabrication.
In the JK, I routed the cable through the floor water drain in the "hidden" storage bin, but If I had to redo it today, I'd probably use an extension and run it out the passenger taillight grommet. You'll already have the passenger side real paneling removed in order to pull the cable from the tailgate.
Alternatively you might investigate what type of bribe a certain DIY guy (<cough cough> @theksmith) would require to help fabricate an over the tire bracket.
/Woody
thanks
Tim
Aw man, I literally just threw all my OEM carrier parts away last month.
Good luck with a solution! Looking forward to seeing what you come up with.
@4x4tographer
Thanks Ryan.  OB1 has reached out, I'm going to send him some plans.
