Murphy 61 Posted May 5, 2024 Reaching out to the community for help/suggestions on how to fix a bent sway bar bracket (2012 jku with stock axles). I pulled the wheel off today in hopes I could figure out a way to bend it back, as I’ve read across other forums where people have done this. But I had no luck. If I can get it bent back straight without damaging it I’d also like to attach new quick disconnects from Apex. Thoughts/suggestions are welcome. Share this post Link to post Share on other sites
ob1jeeper 858 Posted May 5, 2024 14 minutes ago, Murphy said: Reaching out to the community for help/suggestions on how to fix a bent sway bar bracket (2012 jku with stock axles). I pulled the wheel off today in hopes I could figure out a way to bend it back, as I’ve read across other forums where people have done this. But I had no luck. If I can get it bent back straight without damaging it I’d also like to attach new quick disconnects from Apex. Thoughts/suggestions are welcome. Minimally we will need pics of the damaged part you are speaking about, in order to give useable info/response... Share this post Link to post Share on other sites
Murphy 61 Posted May 5, 2024 Hopefully this pic shows up. Sun, Apr 28, 2024 at 1:45 AM.pdf 1 Share this post Link to post Share on other sites
ob1jeeper 858 Posted May 5, 2024 This is an easy to straighten part, with proper knowledge & tools. If you don't have the tools or experience to do this, may I suggest you give Joe @ On-Point a jingle, as I know he has the tools and knowledge to do this quickly, and correctly, at reasonable $'s. 2 Share this post Link to post Share on other sites
Murphy 61 Posted May 5, 2024 19 hours ago, ob1jeeper said: This is an easy to straighten part, with proper knowledge & tools. If you don't have the tools or experience to do this, may I suggest you give Joe @ On-Point a jingle, as I know he has the tools and knowledge to do this quickly, and correctly, at reasonable $'s. Thanks for the suggestion, have seen Joe’s name pop up in these threads before. Tools do seem to be gap as it doesn’t feel that hard. 1 Share this post Link to post Share on other sites
