A6Jeeper
FOR SALE - Dometic CFX 65DZ Dual Zone Fridge/Freezer
Posted (edited)
FOR SALE - $350.00
CALL BILL - 602-758-3500
New $1,149.00
Lightly used (11, 3-5 day trips in AZ, UT & CO)
Description:
The Dometic CFX 65DZ was engineered with the most adventurous traveler in mind. Featuring a weatherproof construction, and a hermetically sealed Waco compressor, the CFX 65DZ will perform in the most extreme conditions. The CFX 65DZ also features an easy to use soft touch digital control panel that utilizes the internal temperature sensor to ensure your food stays at the exact temperature you desire. With the ability to utilize multiple power sources the CFX 65DZ can be used in your car, RV, home, boat, or off the grid utilizing solar. The hi-tech Dometic CFX Series refrigerator/freezers refrigerate or deep-freeze food down to -7°F without the need for ice. The CFX Series models are also fitted with heavy duty features like reinforced corners, stainless steel hinges, and a robust lining to perform in the most extreme conditions.
·         Advanced compressor electronics ensure ultra-low power consumption using AC, DC, and solar power - enjoy the freedom to go off-grid.
·         Enjoy 60% more storage capacity in the same exterior space! Compared to similar capacity ice chest using recommended ice/content ratio.
·         3 Stage Dynamic Battery Protection System automatically shuts the product off to prevent a dead car starter battery and improves car battery performance.
·         Precisely control and monitor temperature +/- 2°F via a digital display.
·         Energy-efficient LED interior light.
·         Drain plug allows for easy cleaning, plus the lid's hinges can be reversed for convenient loading.
·         Innovative USB port for charging small electronic devices.
·         12/24V DC and 100-240V AC – Includes 2 power cords
Specs
  • Gross capacity of 2.2. cu. Ft. / 60 l to fit up to 106 cans and upright 2 l soft drink bottles
  • Dimensions: 22″ H x 28.5″ W x 17.9″ D (725 x 561 x 455 mm)
  • User-friendly digital temperature display and suitable for solar operation
  • Excellent cooling performance even at extremely high outside temperatures
  • Heavy-duty design with reinforced corners, stainless steel hinges and robust lid coating
  • Energy efficient genuine compressor technology provides fast and efficient cooling and freezing, even in extremely high outside temperatures
  • LED Interior lighting
Input voltage (AC) 120 V   Input voltage (DC) 12/24 V
Rated input current (AC) 0.63 A   Rated input current (DC) 5.5 A
Input frequency 50/60 Hz
5/30/24 Outdoor Test in Garage: - See pictures -
Started at 87 degrees & cooled to 39 degrees - took 26 minutes
39 degrees to 25 degrees - took 34 minutes
25 degrees to 16 degrees -  took  18  minutes
16 degrees to  09 degrees – took  14  minutes
Edited by A6Jeeper
price
good deal - i've had this exact same unit in my JK for 6+ years. i had to replace the temperature sensor ($20) a year ago but otherwise it continues to work great!
Posted (edited)
New Price 7/1/24 - = $350.00
Edited by A6Jeeper
