Posted (edited)
Made my version of a metal bender on saw on “the gram”. The bender I copied was was welded.
The two pieces of angle iron were salvaged from a previous project.
Note: Only the holes marked with red and black were used with the bender. All other holes were preexisting.
1/2” square stock, 3 1/2” long, drilled and tapped 1/4-20 and bolted to the angle iron with CCS’s
Both ends of the square stock don’t need to be drilled.  I only drilled them both because I had the drill press set up
Here I have bolted  a 1” and a 24mm deep socket approx. 1 1/4” dia. on to the angle iron
The angle iron pieces can be slid in relation to each other to accommodate various thicknesses of material.
Note the test pieces on the bench in the background made in 1/8” x 2” material.
These bends were made cold, by hand,  with very reasonable effort.
Edited by jgaz
love it! i have this pre-made thing that is similar in concept but it can't alter the bend radius like i'm thinking you can with different sockets.
Here are three different radius bends made with different diameter 1/2” drive sockets when I was fooling around
