4WLNRN 785 Posted August 30 (edited) Ok folks, trying to help a friend out here and I know you are the best people to ask for help, so here goes….. she bought a 98 TJ (picture below) recently and has been driving it and she says it feels like being on a boat in the ocean while driving. Has a long arm lift on, not sure of the size, but have concluded she is missing the sway bars connects. Does anyone have a set they’d like to part with? Let me know Edited August 30 by 4WLNRN Share this post Link to post Share on other sites
mbuckner 211 Posted August 30 Hello Darryl, Based on the picture, I recommend, buying a new set of quick disconnects. Terflex has everything she would need for $157.00. Easy to install. Just my opinion. Mike 2 Share this post Link to post Share on other sites
dzJeepChic 2,908 Posted August 30 (edited) In the picture I can clearly see that she's got JKS disconnects on there; she's running around disconnected. She just needs to pull the pin on both sides and that sway bar will swing down. The there should be a pin on the axle to connect it to (I can't see that part in the picture). Basically she just needs to reconnect. *Edit* Here's a picture of the front axle with the sway-reconnect pin circled. There are two, located on each side right in front of the springs. I hope she's still got them on the Jeep! I hope this helps. Edited August 30 by dzJeepChic 3 1 Share this post Link to post Share on other sites
ob1jeeper 855 Posted September 1 What Diane said... I will add, that the links appear to be missing the lower bushings. Any shop selling Offroad suspension parts, should have them in stock. 3 Share this post Link to post Share on other sites
4WLNRN 785 Posted September 1 Yup, she was able to find the pieces that were disconnected and has also ordered new bushings for both of them. Thank you all for the help and the advice. 2 2 Share this post Link to post Share on other sites
