Curly 1,329 Posted August 26, 2023 5 minutes ago, WILL E said: Oh! That is sexy! But if you want to go back to old school I think I have one you can have. (personally, I would stick with SEXY) Can't go back now, trimmed the opening. It's Ok, I like sexy too! Share this post Link to post Share on other sites
LaZorraRoja 205 Posted August 26, 2023 Big changes on the way! By the end of next week I'll have a RTT and be fully committed (financially, lol) to overlanding. 2 Share this post Link to post Share on other sites
jgaz 752 Posted August 26, 2023 17 hours ago, Curly said: Can't go back now, trimmed the opening. It's Ok, I like sexy too! Besides, by using Kenworth parts you probably gain a couple hundred ft/lbs of torque😜 3 Share this post Link to post Share on other sites
Curly 1,329 Posted August 26, 2023 44 minutes ago, jgaz said: Besides, by using Kenworth parts you probably gain a couple hundred ft/lbs of torque😜 Lets just hope it doesn't Diesel when I turn it off! 😁 4 Share this post Link to post Share on other sites
WILL E 525 Posted August 26, 2023 (edited) I replaced a pool pump for mom. (keep in mind I am late 50's). The pool place quoted her $4800 because they were going to put in a new variable speed and due to space constraints they needed to replace the filter etc. I found a variable speed for around $700 that fit. Then I installed 4 new ceiling fans for her. Installers wanted $150 for the first fan, $100 for each additional fan. She tried to pay me but finally said, 'Your birthday is coming up, find something expensive you want'. Well, I am a jeep guy so no problem. It's their quick disconnect sway links. Going to get them to work on my 83 Cherokee. We'll see if we can make them work (otherwise, look for a fire sale haha). I was a bit surprised when I emailed them asking if they thought these could work. I got the automated response that they would get back to me but they didn't. Edited August 26, 2023 by WILL E 5 Share this post Link to post Share on other sites
WILL E 525 Posted September 30, 2023 (edited) Okay, a month later. After overthinking this, which is a core competency of mine. I finally got the APEX installed. The problem I ran into was (A) it wasn't made for my jeep so (B) the studs for the sway bar mounts were too long and when attached to my sway bar would hit the frame. I spend a lot of time looking for a wider sway bar. However, there isn't much info out there about how wide different sway bars are. I also came up with an over complicated use of tie rod ends but didn't end up implementing it because (A) the holes were too small and (B) I came up with a better idea. This is the old link. I grabbed the heim joint and came up with this idea The cap bolt attaches to the sway bar. The length of the heim joint pretty much puts the link back in line where the old one was. So overall it worked out okay. I didn't get to test drive it today but I don't see any issues with clearance. This is going to be a nice upgrade, sometimes I wouldn't bother reattaching the sway bar, now it's just a turn of the knob and I am good to go. Edited September 30, 2023 by WILL E 2 Share this post Link to post Share on other sites
theksmith 5,878 Posted September 30, 2023 (edited) @WILL E - looks like a great solution with the the heim! when you get a chance to flex test, you might want to make sure the Apex's shaft doesn't end up hitting the u-bolt plate on full droop. Edited September 30, 2023 by theksmith 1 Share this post Link to post Share on other sites
WILL E 525 Posted October 1, 2023 2 hours ago, theksmith said: @WILL E - looks like a great solution with the the heim! when you get a chance to flex test, you might want to make sure the Apex's shaft doesn't end up hitting the u-bolt plate on full droop. Excellent tip! The old ones, when I left them attached, didn't hit and with leaf springs my droop isn't all that droopy. There's more room than the picture indicates but I have to admit it wasn't something I thought of so I will check it out. This is part of the joys of running old iron but trying to make new stuff work with it. Share this post Link to post Share on other sites
LaZorraRoja 205 Posted October 17, 2023 All accessorized now... Just add dirt. :) 4 2 Share this post Link to post Share on other sites
4x4tographer 3,668 Posted October 18, 2023 8 hours ago, LaZorraRoja said: All accessorized now... Just add dirt. :) Rig is looking great man! Night and day difference from the last time I saw it! 1 1 Share this post Link to post Share on other sites
