OLLIE
Ollie's "BugEater" Build
O&B Fab Light Bar w/PIAA 520 ATP Lights (4ea) - PIAA 580 Fogs on Bumper:
Side View Lights (Hella 75 Fogs):
Rear Facing Lights (Hella 75 Fogs & PIAA LED Inclimate Weather Light):
Lighting Switch Gear (Each switch has a built in fuse):
Oznium Red LED Cabin Lighting & Underside Rock Lights:
Spare Fuse Boxes (Convert to Breaker Boxes):
Relay Panel:
Primary Thermal Circuit Breakers:
The Firewall:
Here's some pics of the relay panel, wiring mess, and reinforcement bar.
I also hardwired my Diamond K9000 Mount while I was at it. Here's where I installed the switch.
Donahoe (Icon) Front Coilovers:
Donahoe (Icon) Rear Shocks w/OME 896 (HD) Rear Coils (I upgraded to the HD's because my daily load out caused my rear suspention to sag 1.5" when I ran MD's):
OEM Rock Rails (First mod to the "BugEater"):
O&B Fab Lower Control Arm Bracket Armor & O&B Fab Reinforced Factory Lower Control Arms:
All-Pro Front Skid Plate:
All-Pro Tranny Skid:
O&B Fab Swaybar Collars:
Safari Snorkel:
10lb CO2 System & Fire Extinguisher:
Cargo Barrier:
Cargo Box (Fits all my daily gear and keeps it from sliding around.):
Air Horn Set-Up (7 Trumpets Total):
Note: If I arm them before getting setting the alarm, they will go off with the alarm system.
Eclipse Sun Shades:
CLOSED:
OPEN (Attach to Window):
I bought a stock roof rack until I can fab my own. I made this expanded aluminum grid for it.:
Ramsey Patriot 9500 Winch w/Synthetic Line:
Door Installed Lifehammers (I got this idea from cruiserlarry):
Installed Fiskars Axe and Sharpener on Rear Cargo Door:
Industrial EMT Med Kit:
Daily Emergency Load Out (All this gear fits in my cargo box/area):
Some progression pictures after I added the ProComp Wheels.
Hey Ollie. Over on Expo, you show a picture where you installed 2 12V plugs on your dash. Did you just have to remove the glovebox to do this or was there more involved?
Marcus
More progression pics...
I was stowing my new ARB Freezer Fridge in my back seat because I had no room for it in the cargo area. I finally dirched the huge Contico box I had in the cargo area and created a home for the fridge back there. Tonight I fabricated a new cargo box for the open space so I had a place to stow my gear. One of the prblems with cargo boxes is access. If it is a top loader you have take everything off the top to get inside. If it is a side loader it can be a pain to stash everything in the box and utilize all the space. So I made a combination of the two.
Side View
Front View before adding memorial.
Installed next to the fridge.
Memorial added.
All packed up.
Here's another build progression step...
Here I added an ARB front bumper with Warn XD9000i winch since my Ramsey Winch wouldn't fit the ARB. I also added a Warn rear bumper. The cargo area has been completely redone to accomodate my new ARB fridge, new HD rear coils w/ Race Runner shocks, new LED tail lights with Manik guards, new dualband Kenwood TM-D710 to accomodate APRS, APRS from Kenwood tied to GPSMap 478 and Panasonic Toughbook laptop computer, new Clarion head unit, and new M-Pack cargo barriers with added gun rack.
I originally installed an Extreme Outback Extremaire compressor in my rig. It was a great compressor. I had it installed in my cargo area inside my truck though. It is a loud compressor and I got tired of hearing it running in my truck when charging my tanks. Additionally, I had it installed on top of my subwoofer and when I changed my stereo to an aftermarket one the subwoofer was made ineffective. The dead woofer was taking space which could be better utilized for more economic gear storage. I started doing research but couldn't find a smaller compressor that could perform as well as my Extremaire. I finally came to a solution when I installed the ARB bumper. I ended up buying a Viair 480C Twin-Pack compressor system. The ARB has enough space in each bumper wing to mount a compressor. I just had to come up with a way to get the intakes up out of the wheel well area due to water crossings.
I installed the compressor in each wing and put a QD from each compressor through the top of the bumper so a have a connection source on each side of the truck. I then ran a 3/8" rubber line down each frame rail back to my 2 gallon air tank to feed my air horns and effectively tie the two compressors together so they air volume to each QD feeds off the cumulitive output of them both. I also valved them so if one fails or if I develop a leak in either side I can run off of one side independently sacrificing half the air volume due to the loss of one compressor. I can live with that in a pinch. I will just have to wait longer to fill a tire. :)
I have also installed the Warn Wireless Winch remote system as well.
Here's the images of the installed system (sorry I didn't get a chance to clean the truck :) )...
Got tired of my sliders in my OEM roof rack and decided to make my own platform. Items used, 1/2" dia all-thread, Nylock nuts and fender washers, 3/8" air hose, 1/8" SS expanded metal, and 1/2" conduit clamps. Will paint the outer nuts black when I get the time.
Miscellaneous Mods:
Yaesu FT-857D HF/VHF/UHF Transceiver w/ATAS-120A Antenna:
Odyssey 1700 Primary Battery (Primary battery is nly for starting and my ham radios. All my other accessories are wired to my secondary battery.):
Dirty Parts Dual Battery System (I will be upgrading the Optima to an Odyssey 1500 shortly. Need to fab a battery box.):
12V Aux Plug Switches (Dash, Center Console, and Cargo Area) - The one above the dimmer supplies power to the lighting switchgear.:
Additonal 12V Aux Plugs:
DASH:
CENTER CONSOLE:
CARGO AREA:
Accessory Switches (GPSMap 498, DVD Player, etc.)
Master Arm Switches (Horn, Compressor, and Winch):
Note: The FJ horn works in normal mode with the master switch off. When I arm the master switch the FJ horn triggers both the air horns and the regular horn.
This is a shot of Center Console:
