tucsonWJ
WJ d30 w/ knuckles free to a good home.
I've got the afore mentioned item up for grabs. I know that people swap in the WJ knuckes to other jeeps just not sure which ones. It's free to a good home so let me know if your interested. Axle shaftes, brakes, and unit bearings are removed.
Still have this. I'll also throw in the d35 from the rear. Any one interested? Going in the dumpster if not.
I am interested but I live in New Mexico. Going to have to check shiping. They are still in good shape?
Are you looking for the whole axle, or just the knuckles?
To be honest with you I just saw your post and didn't want the stuff to go to the trash. Lol, figured it wouldn't hurt to have spare parts around.
That's a lot of money in shipping for them not to go in the trash. I'll keep them around till someone needs them to save you the money on the shipping. Unless you really want them.
i *think* the knuckles work on any dana 30 from a TJ/ZJ/XJ/etc. - they get rid of the inverted "Y" style steering and are often done at the same time someone is thinking of changing to 1-ton duty parts because a new drag-link and tie-rod are needed. changes to the track-bar or it's mounting bracket to keep the geometry correct may be required as well.
more info: http://www.jeepforum.com/forum/f11/wj-knuckle-swap-parts-list-1216365/
Ok we'll thanks for the advice. Sure appreciate it. Have a good one.
Still have these?
Are these complete axles and do you know the gear ratio?
I do still have them. I belive they are 3.55 gears. The axles were bad so the are gone and the brakes are gone as well. Basically just a knuckle to knuckle with the center section for the front. Rear is basically same situation. I belive I hav the shafts but they need new seals.
