Quick Look: Fumoto Oil Change Valve
Fumoto is a Japanese company that has been making mini valves to replace oil drain plugs for a long time. Most sizes/styles cost around $30.
I installed one of these during my previous oil change, so this week's change was the first time actually using it and WOW! It really does make the whole procedure faster and way less messy.
Fumoto has several styles and plenty of thread sizes in each variation. They all feature a spring loaded valve handle that locks into a detent to prevent unintended opening. For the extra-paranoid, there are versions with a small plastic clip giving you a secondary barrier to accidental opening.
I bought part #F106S which has the correct M14-1.5 threads for my 3.6L and is the short-nipple style. Their original style has a long enough nipple to slip a plastic hose onto, but I liked the more compact design. The short-nipple ones require a little plastic adapter for the hose in order to clip it on securely.
Here's the valve installed on my JK's oil pan, you can see the little black plastic clip that I mentioned since I'm one of those paranoid folks:
pcyQKH2ASj6tDkqXcsSZDfnayDK8CALBSqpJ39uE
And this is the little section of hose I cut down from their hose kit (which included straight and right-angle clip-on ends for the short nipple).
cbK19zYqId4I2Uu5euU5sFveDFKhy8GF5GlIAn23
My current lift works out where a 5 gallon bucket will just fit under the engine skid and so I only needed a short section of hose to direct the old oil straight down.
The JK's 3.6L engine takes 6 quarts of oil. I've been buying 5 quart jugs and then using a wide-mouth nalgene bottle to measure out the last quart.
XoWK5YBXVHm9wmdoDXD6ktxTamDgZrRodH47hL1h
I did the whole oil and filter change in 15 minutes with no drips or spills - and no catch pan to clean up afterwards! The only part that's even slightly messy is grabbing the old filter to pop it off its housing. I just have to take the bucket to Autozone every other time to dump the used oil.
So in short, I highly recommend the Fumoto valve. It's really a must-have if you're doing your own oil changes. The only reasons not to get one are if you have a low-rider who's oil pan nearly scrapes the ground already, or if you just like having hot oil on your hands!
Edited by theksmith
Nice write up Kris.
i have to admit when you mentioned installing this before my paranoid self said, “oh hell no”.😯
Then I looked at these at the SEMA show in November and was impressed by what I saw and handled.
The plastic clip appeals to my “belt and suspenders” approach to critical  things.  (I do admit however that I might be even happier with safety wire.) Lol
On the subject of disposing of used oil:
The O’Rileys and Auto Zone stores near me always seem to have full waste oil tanks when I need to dump my waste oil bucket.
My city, Peoria, has a hazardous waste disposal program about 4 times a year where they will pick up right from your house.
They will accept most automotive chemicals, anti freeze etc, among other things.
Under the current program they take whatever container where you have stored the waste.  I’ve had to retire my 5 gallon waste oil bucket but that’s no big deal.
The city contacts me by email well in advance of the upcoming pick up period.  They will assign you a pick up date and all you have to do is put the containers beside your garage and they will be picked up.
Just an FYI.
Maybe Phoenix has something similar.
I had a Fumoto drain valve on my 2005 TJ 4.0 oil pan.  Unfortunately, the end of the drain valve stuck out through the opening in my AEV-Nth Degree oil pan skid plate, so it didn't last very long.  It looks like Kristoffer's skid plate leaves some room between the bottom of the oil pan; my skid plate was flush with the bottom of my oil pan.
 I went with one of these on my '19 Ram. With the factory plug removed, the stream came down straight onto the swaybar, sending dirty oil everywhere.
These are a great product!
Stumbled across this today - pretty popular on the JL Wrangler Forums: the Valvomax Oil Plug.
Similar in concept to the Fumoto, instead of a lever/toggle design, it uses a knob design. You can connect a tube to it (like the Fumoto) for mess-free oil changes.
Supposedly it has better clearance when you're combining it with certain engine skid plate combinations.
I'm hopeful to find something like this or the Fumoto someday for the transfer case drain plug so I don't need to drop my tranny skid to change the fluid.
fullsizeoutput_11bc_51bc71c6-2c6e-4da0-9
Photo of it on a 3.6L Pentastar, no skid plate:
aa8881dd-ef76-43c9-92a2-163a6f57e259-jpe
Edited by 4x4tographer
Happy Jim Carrey GIF
i'm still very happy with my Fumoto and the company has been around a long time so i don't worry about their seals leaking or anything. i have one on my 3.6L engine, a custom installed one on the trans pan, and Brady has one on his 3.8L engine too - never any issues.
Edited by theksmith
the only downside i see to the Valvomax/Femco design is that if you were to need to go to a shop for an oil change instead of DIY (like traveling on a long trip), then you need to take the special hose adapter with you, else they will just have to unscrew the hole thing i guess. the Fumoto can work with a standard piece of tubing (i think 3/8") or even without a hose at all.
as far as clearance, just FYI, Fumoto also has a newer lower-profile "SX" design that also allows you to rotate the output to whichever direction works best (at the time of install). https://www.fumotousa.com/SX.html
Edited by theksmith
2 hours ago, 4x4tographer said:
i'm hopeful to find something like this or the Fumoto someday for the transfer case drain plug so I don't need to drop my tranny skid to change the fluid.
i'm 90% sure your t-case fill and drain plugs are M22-1.50 thread.
if you have Amazon Prime, you could order the Fumoto version and return it easily if it's not right.
or the "EZ" brand...
or here's the ValvoMax one...
You the man! I'll check out that SX design too!
I need to buy this all in advance - I kick myself for forgetting to buy one every time I change my oil or our Caravan's oil.
