5 hours ago, johnpa said:
Kris, what did you do with that triangle piece behind the rear wheel that sticks out. Cut it bend it back so it doesn't hit the tire?
i trimmed just slightly more than where the white line is in the photo below, and that was all i needed to clear the 37's. of course it depends on your bump-stop extension height and where exactly your control arms have your axle sitting too.
AM-JKLVJ5tF_aTPN12-j2Zaca9bDGO-Vn3XzpW19
Copy, thanks
Just trimmed mine
16 hours ago, johnpa said:
Just trimmed mine
so you gonna post a photo of your rig with the new bigger meats?
had to install a new power steering pump this week, Mopar part #5154400ac. it was a pretty straightforward job, took about 2 hours. 151k miles on the original!
i posted a while back about the frame-end DDB (bushing) in my Synergy trackbar wearing out rather quickly...
this week i got a Johnny Joint rod-end with the correct threads to replace that DDB rod-end, but found that the 12* angle on the Synergy one was in fact critical. the JJ version was not available in an angled version - so i cut, bent, then welded up the JJ one myself.
AJFCJaV0tvOZrtgPP9zyTqt_kHDzzUtMlxkePIdi
ugly welds, but i think maybe they will hold. i built up from the center of the rod with several layers, stopping to thoroughly clean each bead since i'm using flux-core wire.
AJFCJaUUqae7qQYH6TUcjSmekN8RepQySBv7--iu
installed:
AJFCJaWUUfNvHKHT1xTyH2Cnjs_F1Xo2tV1sSlV2
i put the original DDB one in my spare parts bag just in case my custom solution ever breaks.
AJFCJaXDXHP3MVo4pdfqCKaLUmVF6klLJ17fy9MS
i didn't want to drop $300 to $400+ on a different trackbar, nor keep replacing the frame-end bushing yearly. but my main motivation for keeping and improving this trackbar was that it clears my Synergy steering box brace and a lot of other won't. i also like having the sleeved length adjuster instead of a jam nut.
received a new VKS Fab "Felon" front winch bumper today!
AJFCJaV87QgDIH2DtewUdIvv1FLp_uiMMzKDpqlO
this was an unexpected purchase, though i've had it on my "one-day" list for a while. then last week i heard VKS Fab was shutting down. i was able to find a place with one still in-stock, so i snapped it up.
it has somewhat of a unique design in that it's an extreme clearance frame-chop style, yet the winch is still recessed below the Jeep's grille (so as to not restrict air flow to the radiator). all the other frame-chop ones i've seen have the winch mounted at least partially in front of the grille.
AJFCJaXzWuq8kNqO09eyck9A3PiZL4VrgV34gwYA
besides prep and paint, i've got a little bit of work to get this installed. i need to relocate the JK's vacuum pump to under the hood, modify the winch controller box mounting, and adjust my shower nozzle placement.
  • Wow 1
been working with the bumper some this week...
i rounded the sharp edges of the d-ring tabs so they could be used with a soft shackle.
AJFCJaVJ6wsELaaaSLKPLohPAHLGQntS0v3bKI0K
cut out the logo, welded in some filler metal and ground it all down smooth.
AJFCJaVnJZaZRwmMX9_8SbMciKuWzsqMGCbOLLOP
removed the front 2 rock lights, grille, shower nozzle, winch control box, winch line, winch, lower skid plate, vacuum pump, and then finally the old bumper could come off!
then yesterday evening i started cutting. hope it's right - there's no "undo" button on a sawz-all!
AJFCJaV1gYtVvMl1n00_dKaP9biah1xJbXGox_AZ
  • Like 5
  • Wow 2
slow going, having to rearrange some of the winch wiring because everything will be packed in tighter. also need to figure out exactly how to relocate the vacuum pump - all the common under-hood relocation brackets mount in places that i already have something else!
finished cutting and drilling, cleaned all that up and painted the bare metal.
AJFCJaVit5lTVk-o91nL6I2SQYOKWx-j45HmzUBz
stuff that was cut off (the rest of the lower "crash bar" was already removed for my previous bumper):
AJFCJaUCEOGnSu7MvjzvepgPmtLonpLmOqOMEklG
  • Wow 2
