done test fitting and tweaking, everything is nearly ready to bolt in. i think only the vacuum pump relocation is still todo. oh, and the shower nozzle stuff, but that may require some redesign.
AJFCJaU6GsClDoBNhD8IlHUK8W9G8cuxlYQy0tD-
had to do a little surgery on the winch clutch lever. it was either this or cut out a section of the grille.
AJFCJaVOyftMGjjObCa1s46IjD-P7XVdfgdN_wrx
fine-textured paint on the bumper is finished and drying.
AJFCJaVlDQPxPti4ZuEYKH_kC-4EFGrpp5knyTNE
AJFCJaVGUuvDawyxrMFTQlxcpd22cMN9IINuCGak
  • Like 5
Cut It Out GIF by arielle-m
  • Haha 3
decided to mount the vacuum pump behind the PCM like many other relocation brackets. however, since my VoSwitch relay/fuse box was already in that spot, i used its bracket, countersink some long screws, and used spacers to hang the pump below it.
AJFCJaW6YOcfpgZj8gq8uJcz8BPW5fENVDZRmBkW
AJFCJaXmcqhJkf9owRqMoxv4oV1We4_9vsNESZRK
also drilled and tapped a new mounting spot for my fog light. the old location at the rear of the winch wouldn't work anymore, as that part tucks up under the grille now.
AJFCJaVZ3Rnc6KdHcLhSIixlhU1TOYyr30KA2_TN
  • Wow 1
AJFCJaXV595tTvCorMabHsmiOQE-N4GnG9FthKE8
AJFCJaVe7q505XsHQaMN88yP7LFm9ECaaLctlEaW
new bumper is 45 lbs, the previous aluminum bumper and steel winch cradle were about the same. however i also used to have a lower skid plate that was another 20 lbs.
besides the weight savings, the new bumper also shaved off over 3.5" from the nose due to the frame chop and the minimalist design.
AJFCJaXHXiIfciMPeKsnACOBFiSbU9F5gbOxwxv2
my new approach angle is somewhere around 67 degrees (with 37" tires and about 5" lift)!
AJFCJaUDrVNGRV0shIXTgIIFiClCs8hkYZ9kntvO
...or, a full 90* approach for up to a 27" tall ledge.
AJFCJaXqYUTvd1I4CVowl5bsoGPkskE58BNEqrb6
  • Wow 3
I never thought I would hear a bumper replacement and shower nozzle in one sentence. Nice work Kris
  • Haha 5
It’s so whittle!!!!!!
Pia GIF by Australian Survivor
  • Haha 3
Looks really great!!
minor detail on the bumper...
replaced the obnoxiously long mounting bolts with some shorter ones and thinner nuts - and painted them black of course.
AJFCJaVntQqFzr-SDMRQNpYUEgpzOksuWKOm3aYr
AJFCJaWsHi2QD5bXdk_OeCPu93l9j8Kn3upmfiR6
everything is still grade 8, and i don't think the thinner nuts will be a problem - the bolts are in a double-shear configuration with the bumper tightly sandwiching the frame and so the threads shouldn't be subject to any real force - the nuts are pretty much just keeping the bolts from falling out.
Looks pretty nice.  ;)     Just curious.   Had you considered inserting the bolts from the top?
Edited by ob1jeeper
