August 2022 Dusy-Ershim Adventure Photos
@Mac Ruiz, @stockjeep and myself are back from the Dusy-Ershim... what a trail!
i have to sort through a bunch of photos, but here's a couple to get us started...
sign at the North end (finish-line for us) of the trail:
AL9nZEVthZo2jyVSgz12thbf4XTKkGwF8XMSY7ra
Wayne climbing a portion of the infamous Thomson Hill:
AL9nZEV4Q_qeNGOVDrdVxqkzEry0cF4peEtL5YNG
  • Wow 1
  • Love 3
a pano from camp on our last night:
AL9nZEXMSFm4z40WplEqctzR6xFD7vz2HPl57Hzs
  • Like 4
  • Wow 1
beautiful scenery already just coming into the Courtright reservoir area.
AL9nZEW0TqAHTKbZonRuYq7LFm_-2sqpm53evWYA
weird building at Courtright.
AL9nZEVH4AFHvhTEd3xr190tLhH0fs78f92_NGfC
AL9nZEV0XdTKoXo5Lpf4lIjINcGf_UabrCYbJtBr
looking down stream while crossing the dam.
AL9nZEUp7cT_OXrM-o64VggylqZ9EM0I43QHyWq_
the official start of the Dusy-Ershim!
AL9nZEWN5ejDzNhcF5yaINNsPLWYVkjuOzzLyEhU
no time to warm up, just head for the sky straight away.
AL9nZEXcWk3STIOvWKxAzN_8AKHGx1rO_uxq-EVL
AL9nZEXIs7f76GAUtIDR-CSydoX3rSosInnEFlQ1
top of the slab, looking back at the reservoir.
AL9nZEVrnHxzv62rmpUn5z7M1LUeEyTu4liEJGl3
plenty of dust on the trail, but i couldn't even imagine how difficult it would be when wet.
AL9nZEVJ3ChuDpvsRQFXsiHaRZNpMQ3GyumSIMPG
AL9nZEXQQ0r5cHEC0P7DZZvGE6xPnc_EEax2K3vm
most of the trail weaves through very dense forest.
AL9nZEWYKNzbMmXo9Lb4yDXolQyQIu994qFVDIV9
AL9nZEWZ0ncp6N0kbyHMamV19o4XJTMdy--mnNCg
passing by "the bearded man".
AL9nZEXzdbfmsTzSxseY8IfMpgfEtiLhjyn7hPri
Wayne getting into the challenging stuff on Thompson Hill.
AL9nZEWUjNSXmSJk8EJSWnm2jhS5sXvhtAvX5BLw
Thompson Hill is an exceedingly steep, seemingly never ending pile of rocks and dirt. everything from bowling-ball to 40" tire sized boulders shift constantly in the baby-powder soil as you scramble towards the top.
AL9nZEWp46_sotjWANpIgIbTvH6ftK1ZNyuayz2i
climbing the hill is much like a toddler trying to find the edge of the McDonald's play area ball-pit. Wayne and i both had to winch and stack to make it to the top.
anti-stacking purists can relax, the entire obstacle changes from one rig's attempt to the next, there's no evidence left of our having re-arranged the rocks in any useful order!
AL9nZEXp1C657Z1ly99aomApciRba0pRgFWKDNYZ
the Dusy is often compared to the Rubicon, however beyond the fact that they share somewhat similar views of the Sierras, i found them to be completely different animals. the 'Con is like a constant extreme rock crawl, where this was more like a really long extreme trail with plenty of difficult rock crawls mixed in.
AL9nZEXwPrQtgqVA2_pMou4rpLvUEPGo7VikBuCs
the Dusy is also much more remote, both the trailhead and finish are 2 hours from the nearest one-horse town and there's absolutely nothing but forest, mountains and small lakes on the trail. the Rubicon has 3 entrances and cell phone signal at least some of the time, and people run it nearly daily. if you break down on the Dusy, it could be several days before someone came by.
AL9nZEXs45pkRfxqyZJ0RcLgdRq_tc9wBXPAEAE_
AL9nZEWVAJKzCR7UuVdPaFN50ECmD86j2-pb0kVi
Mac led the first day, i led the second, and Wayne wrapped it up for us on the third day.
AL9nZEVGTPFTq5lSZZTux8V6MHCpVkJmjKsXCOKu
some areas had more sandy soil, but much of the roads were black powdery dirt (between the boulders!).
AL9nZEUhka5LVWrRdsG9aBvb8fT0ZuIvzO2U5l4x
the trail crosses several small meadows as well.
AL9nZEUACUkaUCSnTQIz_zSvboaLjrmw2Lf7546v
Mac definitely had the right rig for the trail - a 2 door and 37's. he'd also already run the Dusy many times.
AL9nZEXdUgYud129fQsowzNei8tvozUWV2rTQWzy
Wayne also had the short-wheelbase thing going for him in his TJ, but had to work harder in many places to avoid diffing-out with only 35's.
AL9nZEWZJEcOcVYEu8nLUKygL3N0Ya5EAtaDQjZJ
i don't think there's more than 100ft of straight trail on the Dusy. it's constant turns and lots of those are tight ones between treese and/or boulders. my 4 door was mostly at a disadvantage with all the tight spots, though the 37's helped keep the belly off most of the obstacles.
AL9nZEV6ESHir9zPsH4Ya3c5WTx6zz7xlI8Mmq5j
AL9nZEUR5eOav0FPr-Zv3hee5c5spJxeONTzxodc
even when not climbing, dodging, or articulating, there are still plenty of just plain bumpy sections that keep you jostling around in your seat.
AL9nZEUTZj09a85mm760niOofUK8V-OmaqFvV3g5
there's also quite a supply of "inconveniently placed" boulders.
AL9nZEW7ZOO6E5oop2Gb1OH2TA2rBm_XIKXF_l0W
the forest would thin out briefly at the tops of some climbs.
AL9nZEXfD8IQg2JrojlZnmhtY8PNTV3MkwArtjnV
which rewarded us with great views of the surrounding peaks.
AL9nZEWY-WrO_4QByWmd5aGON3y7yh_JonbW2-VH
we ran across 3 downed trees in the trail. i was able to move one that had broken up into pieces, and fortunately the other 2 were by-passable. a chainsaw would not be a bad idea on this run - there are many places with such thick forest that there'd be no way to get around a large downed log.
AL9nZEXZ2oexhh4DJSD2IM4_FYclG0poAUzaZJ9s
more boulder fields!
AL9nZEWQ3LWmQKPaoDsFjTqwWgL2pftrJQOERbfc
AL9nZEWiwwMP5fdjn0365JUK66jUFI6P9o9dcAuo
Wayne getting out to check the way on Divorce Rock.
AL9nZEWXyZnmAb6AadSK_H0aCEvVxYqSbyRitgWj
it's not a major obstacle, but does provide a little pucker!
AL9nZEWt6uYYRUtTc87S9nKNd2qpkSsOXYT07mmW
more tight forest squeezes!
AL9nZEVg0e33CWHEYuD0uQX_dW1U1ulnEc3EC8Hs
getting close to the end there are several stellar viewpoints.
AL9nZEVaJ0mUDOXLIl-BUSinaQfVsx2lhlJZFsUw
AL9nZEVhCrGk-Yl0RTwHiQfzaT7G1zN6Mnb53GGM
AL9nZEUs-XqTZ9YFN25IEKtc7Wff0VRyfvJmlcLF
the descent during the last hour or so of the trail is really challenging. IMO, it's worse than going up Thompson Hill, mainly because there's a real possibility of can-opener-ing a door on some of the tight turns between large rocks.
AL9nZEUlxhbRsYioSx5-yEJMNXdgNNs8rPHL7arC
nearly done!
AL9nZEX6tfxoAeuktSrPPiLd7evdN1hj-vi-jN1y
that's it, we made it! here's the sign looking back at the north end of the trail
we made really good time since there were only 3 of us, averaging 5 to 6 hours of intense wheeling each day for 3 days.
AL9nZEV4no9ri2HMJZe1DvakfKsEgnavqU8TscCL
we were treated to spectacular 360 degree views at the last night's camp.
AL9nZEX-p0eiERgrE6XqRt7499FEDuezSCli76W_
AL9nZEXbsZSxvsuvJvY42dv-EW0xSUDxq7u2MohD
personally, i liked the Dusy better than the Rubicon. they are equally challenging trails, but in very different ways. the Dusy being much less traveled was appealing to me, and the overall vibe is just more chill even though you're still wheeling your ass off for 3 to 4 days on either trail!
it was great to also not see a single scrap of trash, and very few bypasses or widened trail areas. the Dusy is a pristine, difficult, man and machine testing overland experience.
Edited by theksmith
  • Like 4
  • Love 5
Excellent trail report!!! And pictures. That's God's country right there, absolutely beautiful!
Oh, and I forgot to ask, did any of you need to use the extra fuel you packed?
great question!
Wayne added his 5 gallons early on just to get the weight off the back, Mac i think made it without any extra. my low fuel light came on just before the end so i added my 4 gallons then. i could have probably made it to the gas station with just 1 extra gallon though.
Edited by theksmith
Loved the trip report Kris.   Looks like a GREAT time to be had there.  ;)
I agree!  Great trip report and great pics!  Thanks for sharing!!! Glad you all had fun and made it safely through!!
smiles, ladybug
