Why do roads get "washboards"?
@johnpa, @4x4tographer and myself were just discussing this on our last trip - here's some detailed (though rather long-winded) info on how/why unpaved roads and trails form corrugations:
  • Like 4
Thanks Kris for sharing
  • Like 4
There is an entire science dedicated to the study of corregated road surfaces.   The bulk of my career was focussed on vehicle durability, and determining how to accelerate the damaging inputs in a shortened time-frame, that would match (as close as practical) the damage that a customers vehicle would see over it's "service life", so that durability/reliability could be assessed as quickly as practical.
I learned that wavelength of the washboard is primarily determined by the "spring rate" of the vehicles using the road.   Larger vehicles (think dump trucks, etc.)  have a lower frequency suspension than the typical passenger vehicle, thus on roads primarily used by trucks, will have a longer wavelength washboard, than a road which is primarily used by passenger sized vehicles.   I also learned that amplitude of the correlations are directly linked to the material being used as a base.
The largest action/mechanical reason for initiating washboard on unpaved roads used by "wheel driven" vehicles (as opposed to trailers as shown in the attached video where the wheel is being towed over the surface) is because a driven wheel slips/spins slightly with each rotation, as it is used to push the vehicle forward.   When this occurs, it displaces a slight amount of material that forms the initial "bump", which over time devolves into washboard.
This is most easily seen and demonstrated where the most severe washboard is located...   If you pay attention the next time you are on a gravel road that is washboarded, you will note that the larger levels are found on a hill or in a curve.   Let's talk about the hill first;   The uphill lane will have significantly worse (higher amplitude) corrugations/washboard than the downhill lane.   SO...   If you see me climbing a grade on a non-paved surface...  Driving up the grade, in the "wrong lane", you will know what I do this...   It's less damaging to the vehicle.
A similar material displacement action takes place in a curve, where the tire slips slightly sideways moving material such that the worst washboard in the curve, will be on the outside of the curve.
FWIW: washboard surfaces are some of THE most "accelerated damaging" surfaces most vehicles are driven on.  To make this worse...  Washboards damaging forces are nearly doubled or more when the tires remain at or near "recommended pavement use" tire pressures.    We all know from experience how much smoother the car feels when tires are "aired down"...   and you can bet the vehicle knows this too.
Finally, on the way home from our recent trip took to NM, driving on US64 from Shiprock, NM -to- AZ, we came across a several mile section of PAVED road surface that was washboarded. 🤯     This was a first for me...   I had never before seen a paved road surface, whose sub-base had deformed sufficiently to allow the asphalt surface to become washboarded.
It appears to be a real-world example of washboard formation without the initial surface disruption caused by tire slip, as shown in the above shared video.   I thought it was pretty cool to witness...   Especially for a road surface geek 😇   .
  • Like 4
Related anecdote: the front axle of my JKUR broke (finished breaking?) shortly after the absolute worst washboard I had ever driven on that happened to be on Horseshoe Dam Rd. Right after the washboard I cold plunged the axle into the water and the axle side trackbar mount sheared while in the water. Total damage included tube cracks on both sides of the pumpkin and every rosette weld on the aftermarket tube sleeving broke (and inner tubes spun). Will never know one super nasty washboard incident did all of that or just insured the job was done.
Replaced it with a trussed Mopar J8 axle.
Woody,
From your description of the failure, there is almost no way the welds failed as a result of the splash-down..
IMHO, and experience, the axle welds failed long before the dunk into the water.   The only way a dip in cool/cold water could create catastrophic failure would be for the welds to have been crystalized by sudden quenching of cold water while still VERY fresh from the welding and the weld joints still at VERY NEAR metal fusing/(melting) temperatures.
