DZJeepChic's '96 Expedition Cherokee Project
e!! is looking good
phil
Diane,
Your XJ looks great! What an excellent expedition vehicle. George is quite the mechanic/craftsman. From what it was to "clean as a whistle," your rig write up has motivated me to start on my XJ. I had not thought or realized that the interior could come out. I picked up a bucket of Oxy-clean today to get started. :D
Looking forward to what else you add to it!
Diane,
I'm excited! She's really coming along and she smells better too. Re-mix on the recipe, now he's saying he used Simple Green and Oxy-Clean, not dish soap.
TheK-Man was over last night and suggested maybe a can of clear-coat on the driver's door. It looks like somebody sanded the whole driver's door flat panel?! I wonder if e! got graffitied?
Hey, word to the wise, rinse your hands often while working with Oxy-clean!
d :rolleyes:
TheK-Man suggested I try spraying clear coat on the driver door of -e!-. The entire panel looks to have been sanded down by one of her past owners for whatever reason. I figured it was worth a try so I went to Checker, no wait, Reilly's and bought a can. Cost $6.50 for the large size (I wasn't sure how much I would need, but they have a little can for $5.50).
George made sure it was all clean and he taped it off
This is what the stuff looks like
He did a couple of coats
Done, WOW!
You be the judge, here she is the 1st time I layed eyes on her
Here she is as of this morning
I took her into Scottsdale today and ran errands. I gotta say, she runs great! I had the air on coming back out Shea and she kept up with traffic and never got hot. I think she's a keeper!
d
glad that worked for ya, now if you take some rubbing compound and buff that sucker it'll really shine like new.... but then again, it is a trail machine so who cares!
kSmith is a genious! George is a working wizard! "E" looks great with that clear coat.
D - Per your comment, if you are concerned about her running hot with the A/C on there are write ups for putting vents on the XJ hoods to help with heat issues. With ideas of "E" doing longer and slow speed expeditions in the desert heat, you may want to look into this.
http://www.eriejeeppeople.com/ejpforums/index.php?showtopic=5097
Poor e!; she ran hot most of the time we were gone. George hard-wired the secondary fan when we got to camp Tuesday night, and that helped, but she still heated up occasionally. The Check Engine light came on sometime Tuesday and was on for the rest of the trip.
She competely stalled and wouldn't start while on the trail Thursday (scared the crud out of us), but then we got her started again and made it back to camp no problem. Russ Chung showed up with his code reader; she was throwing Oxygen sensor codes. The Check Engine light went out when Russ cleared the codes but came back on the next morning.
We hit pavement (Hwy. 89 North of Big Water) at 1pm yesterday, too early to camp so we hit it for home. Stopped for gas in Flag. e! wouldn't start after filling up; got a jump but she wouldn't idle. Bought a battery, installed it and got going again. Then we realized the squeek we had noticed was getting louder so we stopped and discovered the CV Joint on the front driveshaft was lunched so we pulled it. That's 13 years of NO maintenance right there.
We really put her to the test on this trip, and she really performed well. This vehicle is awesome on washboard roads; the stock suspension rides really smooth, and also did fine on a few 3 rated sections. Looking back we should have done more to her before embarking on an 1100 mile cruise, but we made it back!
d
glad you didn't get stranded....sounds like a few maintenance items and she'll be just fine!
on the overheating you might try a new radiator cap before you spend too much money on things like water pumps and thermostats and such.
oh and here's the key trick for getting your OBD1 codes yourself, and what they all are:
http://xjjeep.com/2007/09/24/obd-codes/
Dude, thanks for that reference. We're going to print that out and keep it in the glove box for when something goes wrong and Russ isn't with us.
George :cool:
Wow! I talked on the phone a bunch with ya, and always heard about what you were doing to E, but I guess I didn't realize exactly how much work you guys were putting into it. It looks awesome!! I'm way impressed!!
