theksmith 5,874 Posted August 2, 2021 (edited) when my Rubicon SmartBar (the magic push-button disconnect system) wore out, i replaced it with a regular anti-sway bar and some Teraflex quick disconnects. any brand of traditional disconnects are simple and effective, but i've really missed the SmartBar's convenience when i'm out wheeling alone and have to try and perfectly level the rig to reconnect. and so i was super excited to try out these new AutoLynx "just turn 2 knobs" style disconnects! 😋 those 2 pieces replace your existing sway-bar's fixed or disconnectable links. the fancy machined aluminum and blue knobs on top of each one make it obvious these aren't your grandpa's disconnects! with the knobs in the locked position, they pretty much act like standard links - letting your sway bar do its job cutting down major body roll when taking corners like Ricky Bobby or driving a lifted rig on the freeway in the slightest breeze. however, with a quick half turn of each knob, they unlock and can then independently vary in length allowing your mall crawler to mad-flex on even the tallest urban parking obstacle! they work much like a shock, just without any dampening effect - a photo explains better than i can: for most folks, it will only takes a few minutes to adjust them to match the length of your existing links and then bolt them in. my Clayton track-bar bracket had changed where my passenger-side link was mounted to the axle, and so i had a little more work to do. the mounting hole on that bracket was so low that the end of the AutoLynx was hitting the bracket. i couldn't just space it out with washers as that put the new link on a big lean and looked like it would still hit during full articulation. so the first step was to drill a new mounting hole up a little higher in that track-bar bracket. i ended up having to buy a new step-bit and use a right-angle drill to fit in there. of course i then needed to raise the mount on the driver side to match. i didn't have a piece of 1/4" or 3/16" thick metal handy to make a new bracket out of, so i had to butcher my existing tab. with those slight changes to my setup, the AutoLynx fit as expected without any rubbing. the AutoLynx are available in 2 sizes, an 8.5" stroke and a 10.5" stroke. i purchased the longer ones since my shocks have 12.1" of travel. you might be thinking: "hey, those numbers don't match!" - good point, so what happens? well, during extreme articulation, if one shock is fully compressed, then during the last 1.6" of extension on the other side, the sway bar is going to start acting "connected" again. 🤨 that might not matter depending on your exact setup - but i just so happen to have my junk dialed in pretty damn well so that i was using all but the last 3/8" of travel on one shock and completely extending the other when in a full-flex-for-the-instragram situation. and so yes, i did lose some articulation after installing the AutoLynx - about one inch it turned out. i found when the nose is down, i lose that inch on the droop side (that shock doesn't fully extend)... and when the nose is lifted, i lose that inch on the compressed side (that shock leaves an extra inch of travel unused). the convenience of the simple 2-knob connect/disconnect system outweighs that loss of flex in 90% of the wheeling i do. however, it is going to bother me that i'm limited when doing extreme trails or trying to look good on an RTI ramp! hopefully Apex will come out with a third, longer-stroke version. i'm strongly considering making mine fully disconnectable for crazy trails though. i think i'd just need to fab some appropriate size lower studs for them to attach to instead of the bottoms being bolted in - we'll see how that works out. the convenience doesn't come cheap, but they are easier to install and still cheaper than full replacement systems such as the SwayLOC, the G2 CORE Sway System, or the Teraflex Sway Bar System. some of those products do offer multiple rate bars though, so it's not an exact apples-to-apples comparison. i also can't comment on longevity yet. they are supposed to be fully rebuildable (beyond just the rubber bushings). however, Apex doesn't have any individual replacement parts listed for sale yet on their website. in summary, the AutoLYNX are a new solution to a common annoyance. they're simple to install and use, and do work as advertised - but they can limit a really flexy rig just a bit. Edited October 25, 2023 by theksmith 6 Share this post Link to post Share on other sites
SonoranWanderer 720 Posted August 2, 2021 (edited) On 8/2/2021 at 6:39 AM, Trail Toy said: That's a pretty neat and nifty set up but for the $$$ I'll stick to the manual connecting/disconnecting method. 😜 For a JL or JT, there is also the consideration of modifying your front axle. Manual sway bar disconnects require you to remove a mounting tab on the passenger side that supports the factory sway bar link. The AutoLynx solution allows you a “disconnect” that keeps your front axle unmolested. I just installed a set on my Mojave Gladiator (JT) this weekend. I actually bought a set of manual disconnects (JKS), but saw the AutoLynx solution before I got around to taking the grinder to the front axle. I will almost always choose a solution that requires the least modification to the vehicle’s factory design. The extra convenience or laziness factor is a bonus! 😃 Edited June 14, 2023 by theksmith 2 Share this post Link to post Share on other sites
4x4tographer 3,667 Posted August 4, 2021 Holy cow - those things are awesome. I didn't know such a contraption existed. Any opinion on something like this versus AntiRock's system that you never need to disconnect? I know there's a slight loss of flex with AntiRock as well. Also, Gadget has a LOT more flex than I thought. 😱 Looking good! P.S.: Stumbled across your video on DeathBurro 1.0 So. Many. Questions. 2 Share this post Link to post Share on other sites
shellback91 2,332 Posted August 4, 2021 14 minutes ago, 4x4tographer said: P.S.: Stumbled across your video on DeathBurro 1.0 So. Many. Questions. Thanks Ryan, that was a rabbit hole I did not know I needed to go down. I too have questions now. 🤣 2 Share this post Link to post Share on other sites
Stacey and Scott 1,407 Posted August 4, 2021 21 minutes ago, shellback91 said: Thanks Ryan, that was a rabbit hole I did not know I needed to go down. I too have questions now. 🤣 Blah, Blah, Blah...Dogbone. said every computer challenged old person 1 Share this post Link to post Share on other sites
SonoranWanderer 720 Posted August 4, 2021 5 hours ago, 4x4tographer said: Holy cow - those things are awesome. I didn't know such a contraption existed. Any opinion on something like this versus AntiRock's system that you never need to disconnect? I know there's a slight loss of flex with AntiRock as well. Also, Gadget has a LOT more flex than I thought. 😱 Looking good! P.S.: Stumbled across your video on DeathBurro 1.0 So. Many. Questions. My opinion of the AntiRock: trying to be everything, it's not really great at anything. Ultimately it's just a really soft (anti)swaybar. You slightly compromise your on road stability without being to go all ultra sexy flexy. And they charge you premium bucks for it. FYI, per the AntiRock installation manual, you have to trim the bumper bracket on a Rubicon. May or may not apply to an aftermarket bumper. The manual also suggests other trimming may be required. See my previously stated opinion above on unnecessary vehicle modifications when other/better options exist. The AutoLYNX costs less, does not compromise on road stability, and may only slightly compromise sexy flexy, or may not even compromise that depending on your suspension setup. And if you want max flex, like @theksmith mentions, you could enhance them with lower (manual) disconnect pins. Disclaimer: I have manual disconnects on the Rubi electronic swaybar on my 2008 JKUR, and (8.5") AutoLYNX on the 2020 JTM. I think my wife might have grumbled something about leaving her 2015 JKUR alone. Share this post Link to post Share on other sites
dzJeepChic 2,925 Posted August 4, 2021 12 hours ago, 4x4tographer said: P.S.: Stumbled across your video on DeathBurro 1.0 So. Many. Questions. Hahahaha! I can't believe you found Deathburro - that's still around?!? I too had questions, but by now I know that's just K for you. 🤣 2 Share this post Link to post Share on other sites
theksmith 5,874 Posted August 5, 2021 (edited) On 8/3/2021 at 6:14 PM, 4x4tographer said: Holy cow - those things are awesome. I didn't know such a contraption existed. the AutoLynx are a brand new product - i believe the July order window was only the second small batch ever produced beyond a few beta tester kits. Apex's website says their founder previously worked at Fox as well as Falcon (Teraflex). so even though there's some risk trying out a new product, i feel pretty good about them knowing they're designed by someone with plenty of industry experience. On 8/3/2021 at 6:14 PM, 4x4tographer said: Any opinion on something like this versus AntiRock's system that you never need to disconnect? i agree with @SonoranWanderer and have never understood the cult following of the AntiRock - it's just an expensive light resistance anti-sway bar. set-it-and-forget-it is appealing, but i think the complexity/cost of certain things having different "modes" is warranted. there's a reason lockers (versus limited slip) and selectable 4wd t-cases (versus always-on AWD) are the default with people that like to do harder trails. i feel like the same approach applies to anti-sway bars and it's not something i want to live with a compromise on - especially on-road. having a tall flexy suspension and big tire sidewalls, i want the stiffest anti-sway experience i can get on the highway! Edited August 5, 2021 by theksmith 2 Share this post Link to post Share on other sites
theksmith 5,874 Posted September 8, 2023 well figuring out how to have the AutoLYNX fully disconnect for extreme articulation proved more difficult than i imagined... so i switched to the ORO SwayLOC - more details here... i still like the AutoLYNX system and think they meet the needs of probably 95% of people with a lifted Wrangler. 1 Share this post Link to post Share on other sites
theksmith 5,874 Posted December 2, 2025 i ran across these electronic disconnects for the JL/JT, i'm guessing Apex licensed their AutoLynx design to FOX for them to add electronic actuators... https://www.polyperformance.com/fox-jljtqse-parent-fox-qse-electronic-sway-bar-disconnects-for-2018-jeep-jl-wrangler-2020-gladiator-jt 2 1 Share this post Link to post Share on other sites
