scottL 185 Posted December 6, 2013 Cool! I know you have plenty of room in the XJ, but I'm curious as to where you'll mount the compressor? Planning to mount it in the engine compartment close to where the current one is. That way i won't have to rerun air lines or rewire everything. Share this post Link to post Share on other sites
scottL 185 Posted December 11, 2013 Progress: according to the shop, my transfer case was leaking at the speedo cable input & custom fab work was necessary to muscle everything else back together but with any luck i should get 'er back today. Check out how my rock rails are now tied into the frame rail stiffeners: Share this post Link to post Share on other sites
theksmith 5,778 Posted December 11, 2013 Progress: according to the shop, my transfer case was leaking at the speedo cable input & custom fab work was necessary to muscle everything else back together but with any luck i should get 'er back today. Check out how my rock rails are now tied into the frame rail stiffeners: sweet! found my t-case is leaking where the range selector shaft comes out and not the front output seal like i thought. only problem is figuring out exactly which bushing/seal/o-ring it needs... i ordered 3 different versions that just came yesterday so now i just need to get under there and see if one of them is the correct one. Share this post Link to post Share on other sites
Number7 89 Posted December 11, 2013 sweet! found my t-case is leaking where the range selector shaft comes out and not the front output seal like i thought. only problem is figuring out exactly which bushing/seal/o-ring it needs... i ordered 3 different versions that just came yesterday so now i just need to get under there and see if one of them is the correct one. My t-case is also leaking at the selector shaft, hope it's an easy fix. George:cool: Share this post Link to post Share on other sites
scottL 185 Posted December 13, 2013 my t-case looks shiny and new Share this post Link to post Share on other sites
klaykrusher 65 Posted December 13, 2013 She shore is purdy! Share this post Link to post Share on other sites
91AzXJ 2 Posted December 18, 2013 Time to spit shine the rest of the undercarriage Share this post Link to post Share on other sites
dzJeepChic 2,897 Posted January 26, 2014 At Mud Springs yesterday: Share this post Link to post Share on other sites
91AzXJ 2 Posted January 27, 2014 It's looking really good Scott! Share this post Link to post Share on other sites
